Αποστολέας Θέμα: PAM01346 Radiomir GUIDO PANERAI & FIGLIO  (Αναγνώστηκε 4862 φορές)
« στις: Σεπτεμβρίου 11, 2023, 10:54:50 πμ »
THE RADIOMIR PAM01346 GUIDO PANERAI & FIGLIO, A TRULY UNIQUE PIECE AUCTIONED BY PHILLIPS, IN ASSOCIATION WITH BACS & RUSSO
Panerai is proud to celebrate a new important milestone in its history, which has been enriched with innovation in support of its unparalleled tradition since 1860.
Today, 10 September 2023, marks the 30th anniversary of its official launch.
On 10 September 1993, in the city of La Spezia (the home of the Italian Navy arsenal), after the military secrecy imposed on the Florentine company had been lifted, the first timepieces for the civil market made by Panerai were presented to the public: this marked the beginning of a series of achievements and successes that were recognised both in the past and today by aficionados of the brand.
Another memorable date among the many events that have marked the history and values that Panerai embodies today is 18 March 1997, when the Vendome Group, now Richemont, signed the contract in Florence to take over the historic Italian company founded in Ponte delle Grazie.
The iconic events that have been part of Panerai's journey so far will lay the groundwork for the star piece of the auction to be held on 3 November by Phillips, in association with Bacs & Russo: the reference PAM01346, named "Guido Panerai & Figlio" in honour of the historical name of Panerai in Florence at the time.
https://www.panerai.com/content/dam/pan-assets/01-home-page/phillips-auction/angelus-header.jpg.transform.generic_header_image_1920.jpg
The new PAM01346 is a truly unique piece, a historic Special Edition that reflects the glorious history of both fine watchmaking and Italian heritage: Panerai presents and auctions it thanks to a collaboration with the prestigious international auction house Phillips, in Association with Bacs & Russo.
The main inspiration for this reference is the “Ref.Modified 3646”, Panerai's iconic watch from the early 1960s.
A timepiece in which the extraordinary creative genius of Giuseppe Panerai defined a number of technical characteristics of exceptional prestige:
• The replacement of the historical flush lugs of Ref. 3646 with robust metal lugs welded to the case and fitted with a through-screw for attaching the leather bracelet
• The prestigious Angelus movement with 8-day power reserve, which also introduced the small seconds counter at nine o'clock, on this 47 mm case.
• The transparent plexiglass caseback which allowed the movement to be seen.
• The dial has four printed lines (two below the number 12 and two above the number 6) and a seconds counter at nine o'clock.
• The serial number and luminosity index engraved on the transparent caseback.
https://www.panerai.com/content/dam/pan-assets/01-home-page/phillips-auction/Angelus-SF-240_1.jpg.transform.default.png
https://www.panerai.com/content/dam/pan-assets/01-home-page/phillips-auction/angelus-detail-1.jpg.transform.default.png
https://www.panerai.com/content/dam/pan-assets/01-home-page/phillips-auction/angelus-detail-2.jpg.transform.default.png
The historic Angelus SF 240 movement used for the reference PAM01346 Guido Panerai e Figlio" is part of a special supply originally intended for wristwatches, produced between 1955 and 1961, with a mechanism mounted on 17 jewels, which was almost exclusively used by Panerai at the time.
From 1961 to 2006, one of these special historical movements remained at the Villa Panerai in Florence and was later purchased, together with other antique pieces, by Vendôme/Richemont.
The Panerai PAM01346 watch, “Guido Panerai & Figlio”, inspired by the historic Ref. “Modified” 3646, represents a unique, original and one-off opportunity for those who will be able to see, through its powerful historical character and values, a true testimony to the history of underwater watchmaking, which is so exclusively interpreted by Panerai.
https://www.panerai.com/content/dam/pan-assets/01-home-page/phillips-auction/cofanetto.jpg.transform.global_square_image_960.jpg
The case housing the successor to the Ref. “Modified” 3646 is strongly inspired by the one used in the first Special Edition, the renowned PAM21 Radiomir 47 mm. A celebrated reference created in the autumn of 1997, with a platinum case and historic movement from the late 1930s.
For aficionados, we would like to remind you that in more recent times, Panerai has already used Angelus SF 240 movements, for the PAM203 and PAM267 versions from 2005 and 2008.
The basis of these historic movements, which came from the Panerai archives, was the one originally intended for travel clocks, which was then suitably modified to be wound at 3 o'clock and inserted into the watch case.
So, congratulations to the successful bidder, as they will soon own a piece that lives beyond time.
Απ: PAM01346 Radiomir GUIDO PANERAI & FIGLIO
« Απάντηση #1 στις: Σεπτεμβρίου 11, 2023, 11:01:49 πμ »
Για έναν και μόνο, τυχερό και πλούσιο, Panerista
« Απάντηση #2 στις: Σεπτεμβρίου 11, 2023, 03:29:27 μμ »
Πανέμορφο. Επιστροφή στις ρίζες!!!
« Απάντηση #3 στις: Σεπτεμβρίου 11, 2023, 04:20:31 μμ »
Μακάρι να είναι σημάδι για τη συνέχεια.
Σύντομα θα έχουμε εικόνα για τα μοντέλα του 2024 και θα δούμε...
Η αλήθεια πάντως είναι ότι υπάρχει γκρίνια στους κύκλους των Paneristi για την πορεία και την πολιτική της εταιρίας.
« Απάντηση #4 στις: Σεπτεμβρίου 11, 2023, 05:26:47 μμ »
Τι ρολογαρα ειναι αυτη....οταν το πρωτοειδα λεω εδω ειμαστε αλλα στη πορεια διαβασα περι μοναδικοτητας κλπ ..
« Απάντηση #5 στις: Σεπτεμβρίου 11, 2023, 05:49:42 μμ »
Δυστυχως Στρατο, μεσα στους προορισμους του δεν ειναι η Πορτογαλια!!🥲
https://uploads.tapatalk-cdn.com/20230911/2d971023f2c43f7022aee2f695804cc0.jpg
Αποσυνδεδεμένος Megalos
« Απάντηση #6 στις: Σεπτεμβρίου 11, 2023, 10:36:12 μμ »
πανεμορφο .... και αφου θα ειναι του ενος  ποια τιμη θα καταβαλει αραγε ?
« Απάντηση #7 στις: Σεπτεμβρίου 12, 2023, 12:10:34 πμ »
Η τιμή του μένει να φανεί. Σε περιπτώσεις μοναδικών ρολογιών, σε πλειστηριασμούς με χαρακτήρα charity και παρόμοιες τέτοιες περιστάσεις, τα πράγματα και τα νούμερα πολλές φορές ξεφεύγουν.
Προφανώς κανείς δεν μπορεί να πει που θα φτάσει, όμως δεν θα μου κάνει έκπληξη να είναι ένα ποσό των 200.000€ και άνω.
« Απάντηση #8 στις: Σεπτεμβρίου 12, 2023, 01:46:10 μμ »
Σου ανέπτυξα το σκεπτικό μου Σπύρο.
Θεωρώ πως το ρολόι θα ταξιδεύει παρέα με τον Pontroue.
Αν μας έρθει κατευθείαν από το HK, θεωρώ ότι θα είναι και το ρολόι μαζί του.
« Απάντηση #9 στις: Σεπτεμβρίου 12, 2023, 03:01:52 μμ »
Σωστο το σκεπτικο σου Στρατο, μακαρι να ειναι ετσι!!
