Αποστολέας Θέμα: NEW GREEN DIAL RADIOMIR PANERAI  (Αναγνώστηκε 4117 φορές)
« στις: Ιουλίου 11, 2019, 09:47:47 πμ »
MILITARY ORIGINS SUMMARISED IN PIGMENT.
AN ORIGINAL, DISTINCTIVE AND INSTINCTIVE
DEVELOPMENT IN THE RADIOMIR HISTORY
Matt green, in its solidest and most characteristic visual form, makes
a striking appearance on the dial of four iconic classic Radiomir.
Available exclusively in boutiques.
A mandatory matt look, discreet and intentionally elusive in its design. Rigorously
monochrome, because it is specifically designed to merge into the surrounding
background, whatever it is, blending with its shades. It is therefore strategic.
Tendencies of the dark green in its most powerful and material expression, historically
strategic and immediately recognised. To the extent of throwing off the most general
definition of its colour and assuming the very specific definition of military green.
Panerai has chosen this identifying colour for the dial of the four new Radiomir
watches, reinforcing their strong historic identity.
Four interpretations, unequivocally individual in their functions, dimensions and
the materials of which they are made, but conceptually connected by a common
visual code of recognition as well as by the aesthetic language of the Radiomir
case, with its characteristic cushion shape and integrated lugs, solidly constructed
and representative of the “evolved” Radiomir of the 1940s. This was the period when
Panerai came into prominence as the sole supplier of wristwatches to the Royal
Italian Navy; timepieces which were specially developed with the essential functions
required of the precision instruments designed to be used by its commandos. This
latent military background, is now declined in a civilian context, with three models
with cases 45 mm in diameter, made of AISI 316L steel, and one model with a black
sandblasted ceramic case 48 mm in diameter. In these watches the dense, nonreflective
green colour becomes an element that expresses both a connection and a
unique quality, as do the sapphire glass with its marked convexity, the beige shade
of the luminescence and the Italian tanned natural leather strap. A historic heritage
which has been perfectly capitalised and expressed.
Sharing the same uniform, the new Radiomir with a green dial stand out from a
mechanical point of view with a wide range of calibres, all entirely executed by
the Panerai Manufacture in Neuchâtel. The Radiomir - 45 mm (PAM00995) is
fitted with the P.4000 calibre, Panerai’s thinnest automatic movement, and it has two
hands and a small seconds hand. Then there is the P. 4001, a model developed to
supply additional information such as a second time zone, am/pm indication and the
power reserve displayed on the back; this is the movement fitted to the Radiomir
GMT - 45 mm (PAM00998). This mechanism was subsequently modified in the P.
4002 version, which shows the power reserve indicator on the dial, a feature unique
to the Radiomir GMT Power Reserve - 45 mm (PAM00999). Each of the three
automatic movements has a bi-directional off-centred micro-rotor in tungsten alloy
and a power reserve of three days. The only one to have a hand-wound mechanical
movement is the Radiomir - 48 mm, which is fitted with a P.3000 calibre indicating
hours, minutes and small seconds.
Water-resistant to 10 bar (a depth of about 100 metres) and presented in a box of
satin-finished green cherry wood, the new Radiomir watches are supplied with a
spare strap as well as the original one. In beige for the steel versions or black for the
ceramic version, with two loops and functional reinforcing inserts in each of the holes
in the green leather lining.
Prices for each Reference (USD):
·         PAM995 - $11,200
·         PAM998 - $12,000
·         PAM999 - $12,200
·         PAM997 - $13,300
https://i.ibb.co/y697QXm/1.jpg
https://i.ibb.co/84FXmqj/2.jpg
https://i.ibb.co/Fw1F199/3.jpg
https://i.ibb.co/b2PvGQB/4.jpg
https://i.ibb.co/nCXBGNp/5.jpg
https://i.ibb.co/TrZH1Gx/6.jpg
https://i.ibb.co/bstjT7N/7.jpg
Απ: NEW GREEN DIAL RADIOMIR PANERAI
« Απάντηση #1 στις: Ιουλίου 11, 2019, 10:18:20 πμ »
https://uploads.tapatalk-cdn.com/20190711/84998f621f7d8c0625d4e7bd1da28097.jpg
« Απάντηση #2 στις: Ιουλίου 11, 2019, 10:21:49 πμ »
Ανέβασε η Panerai στο instagram ένα εντυπωσιακό βίντεο.
Από κάτω έκανε σχόλιο ένας λουροκατασκευαστής, πως νόμιζε ότι το λανσάρισμα θα γινόταν στις 15/07.
Πως σας φαίνονται?
« Απάντηση #3 στις: Ιουλίου 11, 2019, 11:25:17 πμ »
Tο 995 και το 998 μαρεσουν! Κι ας εχει παραπάνω πληροφορία το 998, μαρεσει πολύ.  :m0121:
« Απάντηση #4 στις: Ιουλίου 11, 2019, 11:36:15 πμ »
Το 995 και το 997 μου αρέσουν.... Απλά με φοβίζει λίγο η διάμετρος... 45 και 48 αντίστοιχα...
Έχω κολλήσει με τα 47αρια.. Ό,τι άλλο φοράω που φαίνεται περίεργο στο χέρι μου...
« Απάντηση #5 στις: Ιουλίου 11, 2019, 12:17:04 μμ »
Πως σας φαίνονται?
995 & 997  :m0121:
Ίσως το 997 να ήταν μια πρόκληση!! ;)
« Απάντηση #6 στις: Ιουλίου 11, 2019, 12:30:39 μμ »
Μου έπεσε λίγο το σαγόνι με το 995
« Απάντηση #7 στις: Ιουλίου 11, 2019, 01:14:17 μμ »
Εμένα επειδή είναι πολύ κοντά σε αυτό που ψάχνω.... μου αρέσει καλύτερα το 999!! :happy: :happy:
Όλη η σειρά όμως είναι πετυχημένη... το ένα καλύτερο απο το άλλο και αυτό φαίνεται και στις δικές μας επιλογές.
« Απάντηση #8 στις: Ιουλίου 11, 2019, 07:15:39 μμ »
πολύ ωραία... μου αρέσουν πολύ .... :o :o :o
« Απάντηση #9 στις: Ιουλίου 11, 2019, 11:34:45 μμ »
Πανέμορφα!!!
