Αποστολέας Θέμα: PAM067 Radiomir Zerograph SE  (Αναγνώστηκε 1326 φορές)
« στις: Δεκεμβρίου 05, 2017, 05:56:14 μμ »
To Zerograph είναι Special Edition που κυκλοφόρησε το 2000.
Κατασκευάστηκαν μόλις 99 ρολόγια τα οποία χρησιμοποιούν μηχανισμό από τη δεκαετία του '40, κουρδιστό Lemania CHT 15.
Κάσα 42 χιλιοστών σε λευκόχρυσο, ενώ και το όμορφο buckle είναι κι αυτό λευκόχρυσο.
Παράθεση
MOVEMENT – Hand-wound mechanical, Lemania CHT 15 from the 1940s, 15 lignes. 21 jewels, Glucydur® balance with Breguet overcoil, 18,000 alternations/hour. Hand finished. Incabloc® anti-shock device. Power reserve 40 hours.
Lemania produced chronographs for the British Military from the 1940′s onwards, the majority of them having just a single pusher; subsequent presses of the pusher start, stop and reset the chronograph and there is no way to restart the timer without resetting. The earliest watches were built around the Lemania cal. 15CHT and later models, introduced in the 1960′s, were powered by Lemania’s excellent cal. 2220. Lemania cal. 15 CHT was derived from a pocket watch movement. Lemania movements we used in prestigious chronographs by Patek Philippe or Vacheron Constantin.
FUNCTIONS – Hours, minutes, small seconds, single-button chronograph with two counters.
CASE – Diameter 42 mm, 18ct solid white gold with removable wire loop strap attachments. Winding crown personalised OP. White gold single button for the chronograph functions at 2 o’clock.
BEZEL – White gold.
BACK – See-through sapphire crystal.
DIAL – Black, with luminous hour markers and Arabic numerals at 6 and 12 o’clock. Black chronograph counters. Minute counter at 3 o’clock, seconds at 9 o’clock, centre chronograph seconds.
CRYSTAL – Sapphire, formed of corundum, 1.5 mm thick. Anti-reflective coating.
WATER-RESISTANCE – 10 bar (~ 100 metres).
STRAP – PANERAI personalised alligator strap and white gold buckle.PRODUCTION – unique edition of 99 pieces in 2000 only.
https://cdn2.chrono24.com/images/uhren/images_33/s0/2828033c_xxl.jpg?v=1
https://cdn2.chrono24.com/images/uhren/images_33/s0/2828033g_xxl.jpg?v=1
http://pds.exblog.jp/pds/1/201407/07/08/e0181908_16413581.jpg
https://i.pinimg.com/736x/b7/6d/38/b76d38bbc8644c1317065772a9b3dddc--white-gold-closet.jpg
https://www.classicdriver.com/sites/default/files/styles/two_third_slider/public/watches_images/feed_486738/panerai-zerograph-pam-00067-18k-white-gold-lemania-caliber-limnited-edition-no-1-box-papers-bj-2000-service-2014-a_0.jpg?itok=cKl3LlFx
Πανέμορφο reference.
Από τους σπανιότερους χρονογράφους της Panerai, θα ήθελα πολύ να το δω από κοντά.
Υπάρχουν πολλά υπέροχα κομμάτια που έχουν κυκλοφορήσει κατά καιρούς...
Απ: PAM067 Radiomir Zerograph SE
« Απάντηση #1 στις: Δεκεμβρίου 05, 2017, 06:53:00 μμ »
Κι ένα βίντεο.
Πραγματικά μαγικό ρολόι...
